Old 2nd May 2006, 13:18
Stuart Stuart is offline
Stuart is on a distinguished road
Patrick you are nearly correct.
The rear fiberglass body when sat on the chassis correctly will have sheet metal directly behind the area of fiberglass the striker will fit. Mine has about a 30mm hole in the fibreglass and a 12 mm hole in the metal the stricker fits these and the plate in your picture fits behind the metal of the chassis. I will endevour to get a couple of photos and post them for you.
Old 2nd May 2006, 16:36
Patrick's Avatar
Patrick Patrick is offline
thank you, im sure i have a copy of the paper manual in a folder somewhere!
Old 3rd May 2006, 16:47
Patrick's Avatar
I have a good read of the ford manual and I've put the latches in the doors today. I still dont quite see how the striker pins should attach to the chassis - here's a few pics of where I am:
Unless you need to bend the bit of metal on the chassis where the rear fiberglass attaches?
More pics here: http://www.msportster.co.uk/detail.asp?cat=10&offset=12
Old 3rd May 2006, 17:01
Patrick,
oh dear, i hope i am wrong but it looks like there is a piece missing from your chassis?
Take a look at this dutch guys website in his section called Building Part 2.in a section titled "Next Milestone"
http://www.marlinsportster.nl/
In his words.............
The chassis missed the brackets to put the door pins on. Somehow forgotten? Don't know, but after some emails, I got a nice pair of brackets from Mark to bolt on. Perfekt Job from him.
I hope I am wrong?
Peter
Old 3rd May 2006, 17:14
Patrick's Avatar
I hope not guess i will have to send some pics to Marlin to see what they say
Old 3rd May 2006, 18:45
It certainly looks as if the mounting plate for the stricker is missing from your chassis.
Old 3rd May 2006, 19:30
Wink
Hey Patrick,
look at the postive side of this, you'll have an adjustable striker plate for that perfect door fit!
We'll all be sawiing ours off to make them adjustable like yours!
