14th October 2013, 21:18
My mx5 based plug
Okay so im creating a new kit based on an mx5 donor. The kit will consist of a chassis and shell and then all the bits from an mx5.
Few shots of where we are at the moment. I will be changing a lot of the lines to create a totally new design.
15th October 2013, 07:48
Nissan,Porsche,Tvr...looks good
15th October 2013, 22:02
Yep - looks good. As soon as the body sides get wider, does this give a problem with door hinge though? Unless doors remain narrow/gap to front wing ala TVR is retained won't there be a problem unless hinge line is moved out?
16th October 2013, 17:05
Why not go down the bond on panel route like the MX250?
Cheaper, No IVA etc and the MX5 chassis is pretty good.
16th October 2013, 17:47
He's already doing that!
16th October 2013, 21:51
Problem of keeping it as a bolt on kit is i dont think i can get the car low enough to work well with the new body. The car in the picture is sitting on wooden blocks to get it that low. If i can get it low enough to work with the body conversion i would consider making it a bolt on kit. My thoughts at the moment though are to make a complete shell and chassis. See below this is the height it currently sits at. I have seen 75mm lowering kits for the MX5 but still would not be enough.
19th October 2013, 19:51
Can't you change the body (wheel clearance esp) to suit? Surely it wouldn't be a big issue, and would retain the suspension as standard.
20th October 2013, 17:16
Think the car will sit to high then and wont look right. Have seen 100mm drop kits so may go down that route and then lower the body slightly.
24th October 2013, 07:58
a litlle rendering
I like it ,make it a bolt on Front and a glue on rear end with a simple
rollcage to prevent flex .I 'm interested.
Just put a few inches in the fender ,like in mine quick photoshop.
regards. theo
1st November 2013, 22:16
The back is fine, to be honest, the front is not!
18th March 2014, 22:55
1st April 2014, 22:01
Wheel spacers for cosmetic design purpose these are just to get the wheels in the correct place not for road use.
10th May 2014, 16:24
11th May 2014, 12:52
Like the door idea, only changing part of the original... you obviously like TVRs?
11th May 2014, 12:59
Gary. I do like TVR but when this is finished it will look nothing like a TVR. It will be a new kit not a replica of anything. Something new for the market.
11th May 2014, 14:12
Just inspired... very nice.
14th May 2014, 21:42
So opinions on keeping it as a convertible with a custom tonuea cover. I will also be able to use the coupe roof to make a fastback.
18th May 2014, 19:29
Few shots in the sunshine today as it needed a wash. Wheels are spaced out but think i may go another 10mm. I will now be able to work out the correct offsets for the wheels that will be going on when finished. obviously still needs to be lowered. Thinking coilovers 60mm drop and may need to bring the arches down a bit and then it should sit right.
31st May 2014, 18:31
Lowered look anyone
10th June 2014, 14:44
Great looking project mate
