30th April 2014, 10:31
Is there an update (inc new pics) of this conversion?
30th April 2014, 20:18
With the run up to Stoneleigh and the Kobra going into production, the SWB progress has slowed somewhat, but we will be back up to speed after the show and a much needed holiday.
1st May 2014, 07:28
Will you have a SWB 'work in progress' at Stoneleigh?
I'm quite drawn to this one, I think it's going to really work.
2nd May 2014, 08:10
Easy does it Mr T!
You know you can't afford a divorce!
8th May 2014, 13:26
The Kobra looks great now it is painted (the blue one) so looking forward to see this one finished and painted before I decide which one to go for :-)
8th May 2014, 14:18
Puma931 , everything comes to those who wait! obviously i beleive that the SWB is the one to go for and having seen some of the work done by Chris and Dan the waiting will be worth while , Geoff .
8th May 2014, 14:28
I may not have a car to attach it to , but i do have a Made In Italy (Nardi) wheel , Geoff .
9th May 2014, 16:36
9th May 2014, 16:44
You might want to sand that a bit before you take a cast from it.
looks good though
9th May 2014, 17:57
looks good though
Chris there is always somebody who wants to pick holes in your work Geoff .
9th May 2014, 23:29
This is looking very exciting
17th May 2014, 14:37
Is the plan to use the BMW doors as is, or to re-skin them?
30th May 2014, 20:37
We are planning to retain the Z3 doors and over skin them.
30th May 2014, 20:43
Here's an idea that may or may not work, replacing the side windows on a Z3 softtop with one's from the "coupe". I need to do some photoshopping....
Filling on the wooden buck is still plodding on, pun intended!
30th May 2014, 20:44
Helps with the continuation of the design language :-)
30th May 2014, 20:46
Quite like the side vent . Hint hint
30th May 2014, 21:03
If you knew of anyone could adapt a mold ;-) so as to shorten and use cut outs to vary the size of the vents and bar across.
30th May 2014, 23:47
Good find. The rear of the glass looks much too high though for the roof line of the Swb. But if the window runners allow it to be that angle at the rear what about one made from polycarbonate?
1st June 2014, 16:02
But if it fits with the glass a bit lower in the door is that a real problem? Much better than plastic ones surely!
