10th January 2007, 20:59
Very nice Robin, I like your switch gear mounting, very clean!
Richard didnt get the hoses before xmas and on inspection one of the trailing arms was defect so he's waiting for a new one. We have a rear left trailing (near side) spare with a damaged U joint (going for free if you still need one)
11th January 2007, 07:22
Thanks Patrick - but I think I can manage without "doing a trial" now. I have looked at the spring plates closely and they just seem to be spot welded to an area of the trailing arm that is flat. It should be relatively straightforward (lol) to remove the existing plates and fit my new ones about 1/2" offset.
PS going to look at a 318ti this w/e in Reading 33k miles and fitted with the lux pack - only problem is it's green...
11th January 2007, 07:29
No problem Green, you could always wear those yellow safety glasses and it would appear to be a different colour
Did you get anywhere with looking at having adapters made for the brake master cylinder/server pin? I'm about at a point were I'll be bolting that up for (hopefully) the final time.
11th January 2007, 21:14
No - sorry haven't got any further. My brakes aren't quite finished yet and I was going to wait and see what he pedal felt like one the system was filled.
11th January 2007, 22:40
No problem, might see if i can come up with something on the lathe in the mean time
12th January 2007, 11:16
servo
Have just finished the brakes.As I needed an extra 8mm, I filed the edges of an m8 nut, and popped it in, where it it snug and acts lije an extension. It has worked perfectly, without welding it so I may leave it as it is.
13th January 2007, 21:21
Robin, I've tried this:
Seems ok from a dry run without fluid or servo. Full test will have to wait until I've put fluid back in the system. Going to need to glue this in place some how, probably with silicone sealer. Given the shroud (?) is so big on the BMW master cylinder I can see this ever falling out, but it could reposition depending on the speed at white the piston retracts when you lift your foot off the brake.
21st January 2007, 19:35
Update
Finally got round to sorting out the problem with the rear spring plates being in the wrong position. I moved the plates on the trailing arms to match up! It actually turned out to be much easier thatn I expected.
http://myweb.tiscali.co.uk/martinclan/pictures4.htm
Enjoy
14th April 2007, 16:28
Update
Some pictures of trial fit of MX5 seats and inertia real harnesses. Has created more questions than answers!
Enjoy
8th September 2007, 16:52
Pictures of propshaft from DaveMac (£145!), reinforcing of bulkhead top (boring but essential) final fitment of fuel tank plus some other stuff.
Fitting the reinforcing tube was a PITA because I had to relocate some components I had already mounted, leaving me with a few spare holes :-(
I decided that it would be very difficult to seal around the fusebox and so I decided to drop it into the top of the passenger footwell and provide access via a plate over the hole where I originally intended to mount it. Need to make a small shelf for it to sit on.
http://myweb.tiscali.co.uk/martinclan/pictures5.htm
8th September 2007, 20:12
Looks like some good progress, Robin.
Your propshaft looks very nice.
My bulkhead top is not flat, so the scuttle closing plates only touch at each end. Does your extra tubing pull it up flat?
cheers
Peter
12th September 2007, 19:40
cheers
Peter
The extra tube pulls up the bulkhead so that it is flat for most of the way. I just had to use a thick washer in one place to pack it out. Considering I had a 1/4" (6mm) gape before its a great improvement. Gives more confidence with the brakes to - in that you can stand on the pedal and the bulkhead no longer moves!
BR
31st October 2007, 20:12
looking good, Robin.
Looks like your catching me up!
Peter
1st November 2007, 07:16
Peter
Still lots to do yet but I have the advantage of a heated garage only 5 paces from the house!
5th November 2007, 17:40
Looks nice Robin, I had lots of fun lining the tub up on the passenger side, it stuck out a bit need lots of spacing and padding to get it to line up nicely with both the door and the chassis.
18th November 2007, 17:11
A-panels, nose cone and some Ebay bargains!
18th November 2007, 19:55
Good progress, Robin.
I can see the benefits of a warm garage!
Bad weather meant no progress on my car this weekend :-(
13th January 2008, 17:20
More progress...
Wiring for headlights etc, nose cone and side bonnets fitted - top bonnets next!
More pictures here!
http://myweb.tiscali.co.uk/martinclan/pictures7.htm
