Old 21st December 2011, 18:21
nilfish76 nilfish76 is offline
nilfish76 is on a distinguished road
Default Cerificate of newness
Hi all, Certificates of newness which are reqired by IVA test for new registration should be obtained from the manufacturer, i am debating on geting a kit car and was wondering how you can check that the certificate of newness from the manufacturer is valid, is there some registration that the manufacturer has to go which we the public can view?
Old 21st December 2011, 19:17
It's just a formallity for registering the car, it should have the manufacturer name and chassis number on it and a declaration that this chassis is new.
Technically if you read the rules to the letter, you should only need it if you buy all of the major components from the manufacturer but the DVLA wouldn't register mine as "new" unless I had the certificate. It's not a big deal, just a bit of paper
Old 1st January 2012, 21:27
Default IVA tests and Q plates
I really dont want to have a Q plate car, if i went the route with IVA and get an age related plate would i be able to still get a cherished number plate which would be the Suffix plate style IE " HJU 238L" this would be a 1970's plate which would make my car look more like the original???
Old 19th January 2012, 17:04
ZeroJS's Avatar
ZeroJS ZeroJS is offline
ZeroJS is on a distinguished road
As I understand it you have several options with IVA as follows:-
Using the donor vehicle V5 document and proving all major components came from this vehicle will get you an age related plate as above.
Using all new components and providing certificates / reciepts to prove they are new. You are allowed one component to be reconditioned. Will give you a new registration number and a brand new car.
Being unable to provide proof that a vehicle has been built using a donor or new parts will result in a Q plate
HTH's
