Old 7th May 2014, 07:52
woodsmith woodsmith is offline
woodsmith is on a distinguished road
Default Propshafts (MGB)
Hi all,
It has been a while but I am building again. Still working on the electric vehicle which was a reverse trike but as an MGB rear axle came along, and with a bit of careful weighing, I have changed to a quadricycle layout.
With no gearbox the motor is going just behind the front axle cross member, also an MGB item, with direct drive to the rear axle. That makes it about 5' or so of propshaft.
Anyone know which cars/vans would have long two piece propshafts that have the same flange fit to the MGB axle?
I am happy to 'cut and shut' a prop to get a working prototype that can be balanced later on but one that is closer to what I need would make things easier.
The motor end is still open to variation so that end is less of an issue, but a bolt on flange mount would be preferable.
Thank you.
