9th May 2015, 15:13
How do you take the top off the front shocks?
I have the shock off the car and spring compressed
Okay, the spring isn't fully loose but there are only three coils to squeeze and my spring compressor is maxxed out
I thought I would just undo the bolt on the top but that just spins the whole shaft. Short of sticking some grips on the silver shaft and hoping, is there a better way of getting it apart?
There is a 22mm bolt with the little 8mm sticking out the top. It is the 22mm one that spins the shaft. I can't hold that still and turn the 8mm because the 22mm socket cover the 8mm bolt
Getting frustrated now!
9th May 2015, 15:14
9th May 2015, 15:38
No 1/2 in socket in 22mm so still no way to stop the shaft spinning while I try and undo the 8mm. Grrr!
9th May 2015, 16:02
Given up. Getting beer.
Any better suggestions?
C'mon Chris, tell me how you did yours please
9th May 2015, 16:30
Does'nt a ring spanner hold the 22mm while undoing the 8mm?
9th May 2015, 19:27
Since you will not use these shocks anymore, put a gripper on the piston and unscrwing is easy....
9th May 2015, 19:53
I know 2 ways to open it - The first of all ist the mechanic way - u take an air pressured tool Wheel Gun? and put it on the 22mm
or the 2nd way u use a extra tool to open that screw. In Germany it costs about 80 Euro
http://www.ebay.de/itm/like/37130302...pid=106&chn=ps
hope it is usefull for you
9th May 2015, 20:06
I made a special tool for the job, weld a ring spanner to the top of a 22mm socket leaving the square section hole free to get an 8mm socket onto the centre shock shaft.
If you shear the hex head off the centre shaft you can carefully (you may need to look that one up Nick) cut the top coil off the compressed spring with an angle grinder to give you enough room to grind a flat section on the shaft and use mole grips to hold it whilst undoing the 22mm nut with a socket.
9th May 2015, 20:11
The 8mm is the shaft, the 22mm nut is the one to undo
8mm Allen head socket with a small extension bar through the socket and grip the 22mm nut with mole grips
If you don't have a socket that the extension bar will go through, try wedging some pliers either side of the nut, it shouldn't be that tight
I used an 8mm socket with shaft that cam with some decking bolts
Good luck
10th May 2015, 07:22
And today I will be borrowing a 22mm socket with 1/2 inch drive.
The only 22mm socket I have is on 1/4 inch and I don't have a ring spanner to fit.
Anyway, at least I have a plan now.
10th May 2015, 08:33
...or, if you're not planning on reusing or selling the old shocks, just cut through the piston with an angle grinder (once you're sure the separated bits that will fly apart aren't going to damage windows/vehicles/limbs/eyeballs) then you'll be able to grind flats on the stump and hold it in a vice while you undo the 22mm nut. Fast, safe (?!!) and simple.
10th May 2015, 08:47
Keep up the good work WCA and please keep the updates coming. I have just ordered myself a set of coil overs for the SWB build so its good to read the potential problems before I tackle the process myself.
10th May 2015, 09:42
Gaz - I am sure I will find ALL of the potential problems
10th May 2015, 10:08
I do not feckin believe this
I was waiting for my mate to turn up with his socket and thought I would give the 22mm one more go and it came of easy!
God only knows why it wouldn't move yesterday, perhaps the spring was pushing against it but I haven't changed a thing and now it is loose.
Anyway, the build progresses
10th May 2015, 10:57
I reckon the spring must have been pushing against the plate a bit because the second one came off real easy.
Spring compressor doesn't fit the smaller diameter springs. Grrr.
Mate turned up with his 1/2 in socket set (too late) and was able to push the spring down enough for me to stick the bolt on a tighten a bit. Yay!
Off to machine mart to pick up the spanner as hitting the collar around with a bit of wood is tedious
10th May 2015, 17:24
Finished.
Looks like this
Had to remove a bit of the wheel arch from this
to this
To achieve this use a 4cm gap between the top of the bottom plate and the bottom of the locking adjustment
10th May 2015, 17:46
Finished.
You're probably used to the well impressed expression shown by your on-looker
I hope you've locked the two nuts together or we'll be reading about that in a later episode
10th May 2015, 17:56
The bottom one is fixed. There are two at the top that lock against each other. Will be checking all is still tight in a few days time before ragging it too much
11th May 2015, 12:52
Quick blast around the New Forest confirms that I haven't cocked up the handling, the ride height is fine and nothing fell off!
Happy daze :-)
11th May 2015, 13:56
Looks nicer lower down ...def. enhances the car
