Old 18th October 2021, 15:26
belgian2b belgian2b is offline
belgian2b is on a distinguished road
Default MX250 lights wiring
Hello,
i am slowly finishing the car.
I connected all lights, and everything is fine, except front low beam.
I just took the original mx5 lights and connected the new lights.
Is there something i should do about the popup lights ?
I only can find one relay, and it is called "retract". How can i check it ?
thanks in advance for your help
Gerardo
Old 19th October 2021, 18:21
Hi, I assume you’ve used the standard type bulb with 3 connectors on the back?
You should just be able to push the MX5 connector block (you may need to extend the wires) onto the bulb. Easy .
Old 22nd October 2021, 14:24
Thanks for your anwser.
yes , i use a standard 3 connectors lights.
i have extended the wires.
i have taken all the pop-up assembly out .
Should i bypass the connector of the pop-up ?
Gerardo
Old 22nd October 2021, 18:20
Gerardo
No need to as you don’t need it . Just leave it alone
