25th April 2012, 07:45
How long can you wait? I'll be making some out of ali but workload means I'll not have time for it until the end of May. It'll cost you postage plus about five bob for the ali for either a round ball type or long one like the C Types had.
Len.
25th April 2012, 08:34
Thanks for the offer S and WCA, but i really want to make it myself. I have bought some ali 50mmx100mm. I have done the shotblasting, trying the welding. i have the powdercoat equipment/oven, and will probably do everything else as well. Something i am looking for is a DVD on rebuilding my 6cyl. engine?Here the picture of the gearknob.
25th April 2012, 14:53
If you do stumble across a vid please share the link as i've always said that after an initial summer of fun, i'll most probably be rebuilding mine in the winter.
25th April 2012, 15:12
26th April 2012, 12:18
Re-bushing
The picture of the vice and ply reminded me of all my efforts in getting the new bushes in using G clamps, large hammer and all sorts.
I then had a divine inspiration moment and got some threaded rod, and washers some sockets to pull against....plenty of washing up liquid and heyho a bush replacement tool....they wound in with no effort at all...
The removal of the old ones was a bit of a bitch.....I drilled through the rubber and then had an old log with a hole in....placed an old bolt a washers in the bush and beat hell out of it with a lump hammer....in the end with suprisingly good results.
27th April 2012, 18:12
gary after seeing you picture, i jumped on a lathe and knocked up this little beauty, with sammio engraved on top , just to tease you a little...
27th April 2012, 19:43
oooh, nice work Mulberry.
27th April 2012, 20:55
That's cruel, Mulberry. You cut me deep...
28th April 2012, 08:31
Hmm, lathe you say? I wonder what industrial injuries I could inflict on myself with one of those bad boys?
28th April 2012, 09:46
Does anybody know what the thread size is on the gear lever? Is it 3/8".
28th April 2012, 10:19
5/16" NC tighten to 8ft/lb
How do you get a torque wrench on to a knob. (with or without hair)
28th April 2012, 14:57
Thanks Ben, the tap fits the nut just got to see if I have a drill bit?
29th April 2012, 20:49
Thanks for 'Hot Air Gun' tip
Now this was a good idea...
Just knock them out after a couple of minutes, 'Simples'
So i got a couple of things done today, once the rain had stopped. And stripped the brake calipers down as well.
2nd May 2012, 10:30
I was just looking for a picture of a Vitesse wheel with trim and came across these VW Polo wheels that supposedly fit...
2nd May 2012, 11:17
I would double check that as I think the PCD is different on VW.
7th May 2012, 20:41
8th May 2012, 16:21
Dashboard clocks, question. The chrome rim, does it twist off/ or do i lift the tabs up?
8th May 2012, 16:30
Gary
Mine twisted until the tabs lined up with slots and popped off.
Oh and if you need a standard rear spring I have one from my Herald but I dont know what it would cost to send?
Cheers Pops
8th May 2012, 16:37
or just carefully prise up the tabs so you ease the bezel off. They stick with age, and also the glass can be a bugger to get off if they are stuck - patience and a stanley knife blade to ease around the glass works for me!
Good luck!
