3rd October 2012, 09:15
Originally Posted by garyh
Is that called baseball stitching? That looks 'orrible...
I dunno, I quite like the look of baseball stitching. Would look great as detailing on tan leather seats. Not sure I'd want it holding my foot on though...
3rd October 2012, 09:25
Did you ever see the Audi TT, when they first came out? It was a special edition.
3rd October 2012, 09:41
3rd October 2012, 09:53
Oh s**t! I didn't expect that with my breakfast!! That must have hurt. Wishing you a speedy recovery. Quite a lot of g46 planning time me thinks.
I found a rotten pit board in the garage last week and thought I had broken something as one leg disappeared in a cloud of rotted timber and the engine crane I grabbed to stop myself tipped onto me. Luckily for me a footballers sponge and a cup of tea and I was back in action again!
3rd October 2012, 11:06
T'is but a flesh wound...
3rd October 2012, 11:19
Big ouch. Who's a brave boy then!
How did you do it??
3rd October 2012, 12:29
Saving a small child from a grizzly bear or on a ladder, you choose
3rd October 2012, 12:35
Would've been better if you'd left out the word 'or'. I was once confronted by an angry moose that tried to climb up the aircraft steps I was standing on. No, really I was!
Oh, and you forgot to mention it was for cherity mate.
3rd October 2012, 12:45
pforgot to mention it was for cherity mate.
I don't like to talk about that Mate
I was chased around a few bars in Toronto by a 'Cougar'. Was you 'Moose' a similar type of lady?
3rd October 2012, 14:13
No, it was your actual four hoofed angry elk in Goose Bay, Newfoundland. It had me trapped on top of the aircraft for about two hours before it got bored and trampled off into the woods.
3rd October 2012, 16:03
Sammio Spyder bulkhead finish.
In the interests of keeping things busy, I thought I would take the opportunity post some pictures of our modified bulkhead area. We chose to remove a lot of the original Herald stuff not now required, and will be fitting an alternator - hence the old electrical control box will be redundant. Hope others might like the look !
It took quite a bit of fibreglassing over solid block foam to fill out the voids, and hours of sanding back filler. It is quite carefully sculpted around the clutch and brake master cylinders to leave a small clearance behind them. We plan to put an aluminium header tank in the centre where the heater used to be. Hopefully a tidy finished look under the bonnet when all done.
3rd October 2012, 16:24
That looks very slick indeed. Proper factory finished
8th October 2012, 11:11
Something to watch.
BBC iplayer - British Passion on Film - Planes, Trains & Automobiles.
8th October 2012, 21:38
Paul do you want to sell your RB106 dynamo regulator?
8th October 2012, 22:01
mmm confused now, I have a herald with an alternator fitted and the electric regulator box!!! what should I do now?
Pops
9th October 2012, 07:53
Pops
Does it work? If it ain't broke, don't fix it...
9th October 2012, 08:26
Alternator
Hi pshyco pops, my vitesse is the same, the wiring is altered inside regulator box, hope this helps
Kev
9th October 2012, 08:32
Pops
The alternator has the regulator inbuilt so basically the old regulator has been left as a power distribution point. It can be removed if you want to tidy things up. It's along time since I did one but must be details on net somewhere.
9th October 2012, 08:39
Thanks guys,
Had a quick look along the loom as the net says a lot about bunching and re-soldering wires which i am not keen to do, theres a bit of melting on one wire so will investigate if that links in with info available wouldn't want overheating but then may just be coincidence...Pops
9th October 2012, 12:15
Hi Pops,
I was working off other posts on the net saying you could do away with the box or keep it as an improvised junction box if you wish.
Try this link, there are others.
. http://www.northcotts.clara.net/tssc...lternator.html
Seanick: You are welcome to the box but I think has a burnt out link underneath? Pop round sometime & check if its any use to you, otherwise I will bin it.
Paul.
