25th November 2016, 19:13
Sounds like lots of good progress.
I might have missed it posted somewhere else, but who is Glad?
25th November 2016, 19:43
Glan is my mate who is a retired laminator and pattern maker ...he was involved in some early Hot Rod stuff , 34 Corner , Rodshop etc as well as the Wizard Roadster Beetle stuff and early Chesil I think ...he finished his working life at Sunseeker in their development dept ...
I was hoping to get some pics on here today , but spent the morning swapping some engines about and only got a few hours in on the bodyshell ...Glan carried on straightening out the pass. rear and cockpit area ...We made a start on the other wing but didnt get as far as we would have liked ...
26th November 2016, 18:45
I took these pictures today ...although the raised edge to the cockpit is so slight it wont show in the pics ..they give a good idea on the new outline that is being formed around the cockpit ..it will flow into the front dash when finished ..
I spent a couple of hours on the rear drivers side wing this morning ...when Glan and myself finished yesterday , we were struggling to find a measurement discrepancy on the rear ...the tape measure kept contradicting itself and , after a day on the car , we were both scratching our heads , it is no secret that the S*mmio range have wheel arch issues and despite being re-worked , the Miglia has similar irregularities ....I want this body to be as straight as we can manage , so it needs sorting ....I attacked the problem with a fresh approach this morning and dived in at the deep end , cutting the rear wing off !! .....
I am so glad I did ..by moving it back and in slightly at the rear , so the tail is tucked in but the width at the centre of the wheel arch isn't changed ...the wing has corrected itself ..a few slits in the rear section , to correct a twist , and I was able to tape up the gaps and re-glass it in place ...now some big dollops of filler can do the rest of the work ...
26th November 2016, 19:20
Gary - Obviously, I know what a big difference some 'cutting & shutting' can make.
So it definitely worth putting the effort into the plug to ensure no customer has to get the jigsaw/angle grinder out.
The curve along the cockpit sides looks good and will really look the part when it blends into the dash.
26th November 2016, 19:25
As a footnote ...I was measuring several things today and working out layouts etc...I'm not keen on the extended gearstick way that Miglia used to do ...Its not a terrible idea but I want to have another option as well ...The bulkhead is going to be moved back 8'' ...so an 8'' extension on the gearstick shifter will deal with that shift backwards .....but...... if you reverse the suspension towers , left on right and right on left ..you set the engine back 8'' ..it's not a new idea , been done before , but the relatively simple swap over and a new gearbox mount supplied with the bodies , would tackle the same issue and put the engine in a nicer , set back position ...Using a stock Herald prop shortened to suit or a Spitfire one with a couple of little machined spacers either end , again supplied , would get that dealt with too ......I think thats the way I would build this car ...Bolt on towers , bolt in replacement gearbox mount ..no chassis mods ...Happy days ...
26th November 2016, 20:41
A lot of thought going in to this at an early stage,
Can only be a good thing, I think people's expectations are higher now regarding kits, when you look at how straight the DNA and MEV products are now they have set the bar high.
Plus, IMHO if the quality is good the price asked will be achievable, I know you are not going to be asking a kings ransom for this any way but it all helps.
Like the idea of a raised edge around the cockpit, it will also help if the customer wants to fit a flat tonneau style cover and may stop some water blowing in.
27th November 2016, 06:54
Gary - Even if I have my tongue in my cheek at times, I hope I am still being seen as positive/constructive about this new project.
So I just want to echo some of Jeff's key points.
Originally Posted by Jeff H
… A lot of thought going in to this at an early stage … Can only be a good thing …
I think people's expectations are higher now regarding kits … if the quality is good the price asked will be achievable …
Personally, I believe that thinking about how the kit will actually be built is probably more important than how it looks.
As the cost of the kit itself and all the other parts used pales in comparison to the value of the builder's time.
These days, you have a choice of a something like a Tribute Kobra that can be completed in a few short months.
http://www.madabout-kitcars.com/foru...ead.php?t=5001
Compared to 'traditional' Sammio & Miglia projects that can take years to finish, or are simply abandoned all together.
I actually prefer the look of the Sammio to the Kobra, but these days construction time would play a key part in me choosing a kit.
If anything, this Formosa Spyder appears to require more rolling chassis preparation work than any Spyder, G46 or Cordite before it.
So, ideally, this prototype really needs to be fully built up to an "on the road with an MOT" standard before the first kit is sold.
That way, the full list of "extras" required will be known in advance of a build starting.
So far, you are moving the engine/gearbox, replacing the prop shaft, modifying the steering column, etc.
Will you be reusing/moving/replacing the Herald radiator and associated "plumbing"?
Even if all of these jobs are "relatively simple" there seems to be a lot of them.
Therefore it is even more critical that everything supplied works "out of the box" without any further adjustment being required.
Which brings me back to Jeff's original point that all the effort spend at this early stage can only be a good thing.
27th November 2016, 09:17
Paul , THANK YOU FOR THE INTEREST ....I really don't have all the answers yet ..but I can tell you that the car is , as you say , a different build style to the glue-on kits ...I am not totally intending to offer this as a full on kit ..but a bodyshell that fits a Herald or Vitesse chassis that I have come up with the answers to build into a car ...leaving the builder , once again , to put their own spin on it ...I am not offering a replica of anything that has to be built in a specific way ..but , in the same way that Hot Rod bodies are supplied , it will be a case of ''here's your body , it fits this , I have built one like this , but you are free to go whichever route you like ...''
That was the original concept for the S*mmio , but I think some people expected more from it ...
Its a car that is built in the ethos of the old Specials of 50/60 years ago , with a Hot Rod aptitude ..
Touching on your comments about degree of difficulty in build above ...yes , it has more work to do than a S*mmio in some ways ..The Cobra you quoted is a quick build , but some glue-ons are still quite labour intensive ..thats why people like Nubodi charge the fees they charge ..its just different types of jobs ..
I will be able to offer a fully refurbished , fully roadworthy one of these for less than a Nubodi turnkey that isn't fully refurbed underneath ...but thats the different nature of the donors and build styles ...
Most people will , I suspect , strip their donor chassis right down to build the car ...bolting the towers back on on the opposite side , fitting an alternative , supplied gearbox mount , an alternative prop and an extra link in the steering , if required ( I think the stock column may slide back enough anyway ) is going to add virtually no extra time to the re-assembly than a refurbed S*mmio ...likewise , radiator re-positioning etc. is going to be no more involved than a S*mmio build ...extra work will be door hanging , minimized by quality gaps - hopefully ..boot hanging ....possibly pin and latch ..dunno yet ...thats about it ...
The intention is to offer a floorpan that comprises of 2 pans joined by a tunnel with rear bulkhead attached and they will be glued to the cut down front pans that have been shifted back 8'' ... you prep the chassis , fit the rear framework for the fuel tank , fit the floorpan , attach the 2 side rails to the rear frame and relocated bulkhead ..so a moonbuggy with a floor and rear bulkhead , if you like .. the body then gets stretched slightly at the sills , lifted over the frame and locates at bulkhead and rear bulkhead , the sides are pulled in to touch the rear bulkhead and floorpan and bonded on using appropriate glue like stikall or similar or can be fibreglassed in place ...so this process and the lack of having to line the cockpit with ply etc ..will save time in other areas of the build .... so its swings and roundabouts really ...
Reason: spelling mistakes
27th November 2016, 09:18
If you like how it looks then just buy it, worry about the rest later, any problems can be sorted with thought and time and money.
Or just buy an airfix kit that comes with all the glue and instructions.
27th November 2016, 10:27
Fascinating reading. Thanks gents.
27th November 2016, 12:05
Its probably important to add that this bodyshell option is going to be marketed in a slightly different way ...what I mean by that , is that the S*mmio was/is a cheap option ..you got what you paid for , a bodyshell and frame that , with a bit of effort , became a pretty little car for not a lot of money , when compared with similar styled vehicles to the S*mmio etc. .....ie . The higher spec. Porsche 550 / Cobra's , D and C types . MEV etc...
Keeping it cheap meant I needed to bang out lots of units to attempt to stay afloat ...quantity over quality quickly became the situation ..especially as moulds and tooling got tired and there was no reserves to amend that situation ...having experienced bodies from early and later batches ... The first 20-30 were definitely better .
This time , I am not looking to sell lots of units ...so a slightly harder build ( I don't think it is really ) is possibly going to put a few people off ..add to that the bodyshell and framework with floorpans etc. is expected to be around the £2500-3000 mark , primarily down to a higher spec body ..all visible framework will be tig welded round tube etc. ..and I will lose some budget builders there too ...but I am not looking at getting so busy it gets messy again ...so it works for me ..the S*mmio , Miglia and A352 are still a viable option for anyone on a lesser budget .
I wouldn't be too bothered if I only sold a few packages and just built a few cars to retail alongside those sales ...
I would like to think the value of these cars , built correctly , will sit somewhere between high end S*mmio/Miglia sales and decent Cobra / Chesil figures .....I think I can build a turnkey in that range , so hopefully its achievable by most folk .
27th November 2016, 14:20
Gary - I think we are singing from the same hymn sheet here.
As I'd like to see you charging more for a quality kit that you have had time to develop fully.
Although I'm not actually sure that there is a "budget builder" market as such.
Whilst the price of Caterhams, Westfields, Ultimas, etc. are clearly in a different league…
I can't think of any Sammio customer build threads on the forum that have been "cheap" builds, can you?
It appears that people loved the way the Sammio looked and all what to build the best version they can.
Being at the lower end of the price range might have helped people "take a chance"...
But picking up on Jeff's comment, people have put thought, time and money into their builds.
I'd just like to see the build time being limited to construction and personal modifications, not fault fixing.
Jeff - Whilst it is certainly true that thought, time & money will fix most problems…
I'm merely suggesting it would nice not to have the problems to deal with in the first place.
Given the amazing job you did prepping and painting the dark blue SWB 250…
I really can't imagine you telling a customer that with a bit of effort they can fix any problems themselves.
Please Note: I'm not suggesting there will be any problems with your paint.
More that I'd like to see the body shell built to the same high quality standards that you apply to painting.
Anyway, apologies for taking this build thread off topic.
28th November 2016, 17:35
Formosa
Don't take all the fun out of building a one off car I like a bit of head scratching just built a cycle kart out off a lawn mower no tax no lnsuranc no registration lots of racing in France
28th November 2016, 22:30
After a lot of words, I thought I should at least add a photo...
30th November 2016, 18:19
A bit more achieved this week ...I know its not incredibly interesting at this stage but I'm trying to document the build as I go ..and this is as good a place as any to put it on record .....
The dashboard and scuttle area has been moved back about an inch and a half ...I wasn't happy with the long cockpit and want to give the car ''lots of front '' , so this move allows me to bring the bonnet line back a similar amount ...it also means a better position regarding the bulkhead and a stronger platform for the screen... The dash and scuttle are being shaped up using Porsche 356 panels ...
These two pics just show the drivers side starting to be matched up to the passenger side with foam and filler etc... Also a front on pic showing the new line of the scuttle from side to side , if you look at the rear door shuts on either side , it shows the width addition and altered curve to the body quite well ..pass. side is nearly shaped ..drivers side shows original shut and the foam block in the process of being shaped, glued to the outside edge ... ...some blending still to be done ..but we are getting closer to starting on the front end ..which I am really looking forward to ....
I have also started to cut the new bonnet line and lower front wing section ...A piece of Mistral front vent kindly donated by Tributes scrap pile has been tweaked slightly and grafted in to break up this area .....Luckily the other side was in Chris's pile too , so hopefully get that fitted tomorrow ...the front of the Miglia wing is very upright , the curve from the body flattens out as the panel travels forward to the front arch ...possibly as a result of stretching the Cordite panels to fit the Spartan chassis in the early stages of Miglia development.....we have exaggerated the curve along the body and need to do the same on the front wing ..the front arch is due to be reshaped too .... its getting a flatter top line , similar to the rear and a tapered rear edge that will kind of , follow the line of the vent ....so a combination of filling out and re-shaping should 'plump' up that area a bit ...
30th November 2016, 18:44
The new working title for the project at this stage is FORMOSA 120 ..But that might change ...I don't think Spyder is right for this particular bodyshell ...
30th November 2016, 19:15
names
Hi Gary, given the italian influence, i looked up Janus in italian and this came up with Giano, company name ie.Giano Sportscars?, suggested name for the model Sportiva or Italia.
the Giano stands for god of opening/movement has a twin head design if you look this up.
Just some alternative idea's.
30th November 2016, 22:47
Looking good Gary,
My suggestion for the name is "Formosa Finale"
It may not be a S&""!@ but its a fitting evoloution/conclusion to the bloodline
1st December 2016, 06:13
Formosa Centoventi it is then.
1st December 2016, 09:06
120 is approx the number of units sold under the original S*mmio banner by the way .....
