26th November 2015, 16:05
That is a great bit of lateral thinking.
26th November 2015, 16:33
Thanks Paul, its taking its time but I have been working on the car for nearly twelve years so another week is nothing in the scheme of things...
28th November 2015, 14:57
Bonnet continued..
29th November 2015, 15:16
Bonnet continued..
29th November 2015, 20:59
Brilliant work!!!!!!!
29th November 2015, 21:16
Thanks Peter, another weekend gone and so much more to do, I must stop thinking up ideas as I go, it just creates more work, at least when it gets finished it won't be an off the shelf job, must admit it keeps the old mind active, too active sometimes. If all goes well with the bonnet then I can start building up the engine bay....wiring, lights etc then the engine can finally go back in, hopefully with no unforeseen problems..
14th December 2015, 20:58
Bonnet continued..
Now to deal with the gap at the front, first was to cut out a piece of ply to take the shape at the front
Then the leading edge was sanded down to remove most of the step were the ply meets the MDF
Next was to fit the board, it was placed into position and wedged at the rear to maintain the shape at the top then screwed at the front to secure.
Next it was off to the shop to buy some modelling clay, this was applied over the board and around the edges to smooth out the required shape.
This was then left to cure over night……………………… total disaster in the morning the clay had shrunk something rotten and cracked all over the place leaving all that work a total mess so it was all removed ready for a re-think, mind you I wasn’t really happy with how it looked anyway so nothing really lost apart from more time.
I made up some fibreglass strips in readiness for my next cunning plan..
A change of thought so as to add some shape into the bulge, I removed the board then cut it to form vents, hmm that may look better I thought so the next thing was back off to the shop.
Arrived home now armed with plasticine, that won’t dry and shrink so back with shaping, I was going to shape the plasticine into what I liked and make it a bit smaller than required, cover it with cling film and glass over, then remove the plasticine, refit and bond in the glassed shape and apply P38 over to finish and sand to blend.
Right off I went
Hmm this if starting to look like a naff American muscle car, not the image I wanted so had to have a re-think.
Ha I know, I have a intercooler scoop from a Suburu, I could incorporate that I thought, so I removed the plasticine and placed it onto the bonnet to see what I thought…
That’s it.. it will keep the looks of an old English sports car, Aston Martin, Austin Healey sort of thing, so got the old grey matter working again and made a start…
More MDF was required so back to the shop….
First cut to rough size and mark out the shape and lay in place,
Then mark out the underside of the front edge for feathering then sand the front edge down
The front edge was sanded down checking the profile at each line to check progress until about 2mm thickness of the front edge was left.
15th December 2015, 22:07
Bonnet continued
16th December 2015, 18:36
Love the way you are so willing to experiment to get the final bonnet shape you want.
16th December 2015, 20:35
Thanks Paul, I would rather get it right where I can, otherwise it will annoy me forever, may as well build it how you want it I say, it's like having your heart set on a red sports car with black interior and ending up with a grey one with blue interior, not the same thing.....
18th December 2015, 17:28
Bonnet continued
Reason: .
19th December 2015, 15:11
Bonnet continued
22nd December 2015, 20:45
Bonnet continued
30th December 2015, 13:25
Bonnet continued
Right , I hope all had a merry Christmas and received all the parts you require to finish your projects, I have sent the wife back to work and now I can continue with mine….
The scoop for the bonnet has protruding fixing points so I fettled out the plug to suit
Once completed I gave it a quick coat of satin black to find more imperfections and also sealing the bare MDF.
More filler required, so applied around areas to fill any imperfections, hmmm been here several times and getting quite fed up with chasing my tail, I have decided that any small problem areas that remain will be cleaned up from the mould, first I will only need to do some light rubbing down and second the gel coat will be more forgiving as the gel coat is a lot harder than the plug.
Final rubdown and repaint… mask around the car and plug supports and ready to go..
Applied a liberal amount of mould release agent….
Now to hope for the best, a covering of gel coat, I really hope it all releases after all this prep work….
Now the waiting game for a good few hours and then for the glass……
30th December 2015, 21:12
Fingers crossed for you, it's looking good!
30th December 2015, 21:30
Thanks Mr Jones, its always a worry that it won't break out of the plug, first sheet of glass on now and hopefully the edges stay put...
1st January 2016, 16:04
Bonnet continued
Right the mould has all been glassed and support rails fitted….
Once cured the plug and mould was lowered to meet the car……
The profile looks good and then…….
Aaaaarrrggghhhhh…. I need a break
3rd January 2016, 19:30
Bonnet continued
Right worse nightmare ever but needs to be tackled, the plug didn’t release from the mould, well after a rant and a day off I took in the job of trying to recover the mould with limited damage, I ripped off the supports and then scored the surface of the plug, then put some water in and hoped it would soak in and give me a chance..
After an hour and a lot of scraping out the MDF I thought this is not working too well…
After another 2 hours I decided to try something else, scrape it out dry…
2 hours later that got most of it out…
Now for the steamer…..
Another hour or so…..
And another…
Most of it out and now to think about the paint, into work tomorrow to ask my welder for the details of the paint stripping spray he has recently has had good results from…… No more messing with nitromors…
3rd January 2016, 20:09
Oh Noooooo! Sorry to hear of the pain you are going through - it looked so good too. Fingers crossed it can be salvaged.
3rd January 2016, 21:27
Thanks, I will salvage it, it has taken an age to get this far with the bonnet and I will not let this get me down, if I can clean the paint off it should be not too much work to flatten back the gel coat and sort the minor repairs, I think the spray on mould release may have reacted to the paint and caused it not to do its job, maybe the paint was too fresh but hey ho, life not simple and I am no expert when it comes to fibreglass, you live and learn ....
