29th June 2016, 15:47
Wow, that's really good value for someone, just not me. Nice find.
29th June 2016, 15:48
Seats are very tempting but just too far away to collect.
That's a shame, they are very comfy...
29th June 2016, 19:12
Skoda, was my guess too...
29th June 2016, 20:23
Reliant Scimitar has a separate chassis and the engine in the right end..
29th June 2016, 20:42
Mister Towed - It is a shame that you are not going to build a SWB 250.
But at least I can now look forward to your new Outlaw 356 Speedster build thread instead.
As for your donor car options, are you planning to keep it to scale, or 'supersize' it a bit?
Which would open up the Boxster / Audi TT options discussed in this thread:
http://www.madabout-kitcars.com/foru...ead.php?t=5451
Did you see this thread?
http://www.madabout-kitcars.com/foru...ead.php?t=5966
29th June 2016, 21:55
Originally Posted by Paul L
Hi Paul, Speedster will be correct dimensions as original but with a few hidden outlaw surprises.
Yes, I saw that refurb thread, very interesting but I still think it should be named Delilah - Why? Why? Why? Delilah, da da da da da da da. etc.
Build thread will have to wait until I actually build it...
15th July 2016, 08:05
Is it finished yet?
15th July 2016, 15:42
Originally Posted by froggyman
Is it finished yet?
If you mean the 356, no, it's still at the gathering parts stage.
It'll be a slow process putting it together - now I've had a chance to take measurements from the bodyshell it seems that what I actually have is a Banham New Speedster body, which was intended to go on a Rover Metro/100 base, so the wheelbase is 150mm longer than it should be.
That means I've got to take 75mm out between the back of the front arches and the leading edge of the doors and another 75mm out from between the trailing edge of the doors and the front of the rear arches. Sounds simple enough...
19th July 2016, 09:44
Oh a Banham New Speedster.. Rare as hens teeth that!
Did anyone ever build a BNS?
Might be wrong but I had my misgivings re cooling, as the intention was for it to be front engined, water cooled Metro but I didn't think it had anywhere near enough ventilation for a standard radiator let alone one from British Leyland!
Good Luck Mr T, watching with great interest.
19th July 2016, 15:56
Hi Andy, I believe a few got built - there's one in the madabout kitcars picture gallery if you look hard enough - and the demonstrator looked pretty good to me -
As for the cooling issue I have a couple of tricks I'm planning to use to ensure it keeps its cool, like an electric coolant pump, a decent sized copper cored rad and 'brake' cooling ducts in the front valance to allow air into the engine bay.
Just need to find the time to get on with it now.
19th July 2016, 19:17
The demonstrator may not be a working car - or only for a few yards! who knows? I remember many years ago seeing a kit car at Stoneleigh and Newark in all its splendour, but with no prop shaft. Feeling mischievous I asked the company director about it, and he said "oh that's only a minor thing, will be sorted soon" Fair enough, but 4 years later it still wasn't sorted, which begs the question why (and the company went into liquidation.. wonder why?)
19th July 2016, 19:45
...That means I've got to take 75mm out between the back of the front arches and the leading edge of the doors and another 75mm out from between the trailing edge of the doors and the front of the rear arches. Sounds simple enough...
19th July 2016, 20:41
I built a banham an X99
It was one of my cheaper builds but it was even more cheaply laid up.
I spoke to the laminators and they said they could make them better but they were made to a price point.
You made a great job of the Sammio so im sure you have the skill set to end up with an outlaw 356
20th July 2016, 07:59
I bought one years ago as an unfinished project ...They had quite a few issues . The front wings covered quite a few of the engine bay components , things like the battery and electrics were half covered by bodywork with no real easy solution to how to rectify it ..Many items would be impossible to remove once the body was in place....The 550 I built was not without issues but seemed a bit better thought out ...I got the impression the Speedster was developed very quickly to get it on the market without thinking about or maybe caring about how it would be built ..You would kind of accept that if it was cheap , but they were quite expensive at the time ...
I used the body and put it on a modified Beetle chassis that I seperated from an unfinished Charger kit car !
20th July 2016, 14:44
20th July 2016, 14:54
28th August 2016, 09:41
7th November 2016, 18:14
Hows the 356 build going. Did you go for the vw chassis . Was looking at mgf mid engine car. They seem similar size to the metro. And used the same wheel Stud pattern. Cooling might be easier. Though id probably put a Toyota engine in.
7th November 2016, 19:03
I'm going Spitfire chassis and Ford Puma engine. Should be pretty quick.
7th November 2016, 19:04
Good choices!
