Old 30th October 2007, 11:48
DavidH DavidH is offline
Question Digidash?
Hi all,
Still doing some planning whilst waiting to collect the kit mid-Nov. One of teh things I'm quite keen to do is to install a Digidash www.etbinstruments.com in the car. Has anyone else done this, and does anyone know if theres likely to be any issues doing this. E.g. conflicts with the Engine Management Unit over sensors etc being different?
David
Old 30th October 2007, 12:08
BIG_Fella's Avatar
I am using a digidash in my type r kit
As for the sensor the ones for the dash are indipendant to the ecu (Kpro)
I fitted an extra light in my dash panel for an engine management light
I got a tee piece made for the coolant system to fit the water temp sensor
I have a remote oil pressure line in order to fit the oil pressure sender and a remote oil filter to fit the oil temp sender
I have fitted the speed sensor to the fixed drive shaft the bit that is bolted to the engine
Old 30th October 2007, 12:34
Cool, mine is a k-series build (couldn't afford the Type-R) but I assume the same applies that the sensers for the dash and ecu are independant.
Old 30th October 2007, 14:46
Jon@JNRacing.co.uk's Avatar
Jon@JNRacing.co.uk Jon@JNRacing.co.uk is offline
Jon@JNRacing.co.uk is on a distinguished road
I was looking at fitting this but I spoke to a few people that had it fitted in other cars and they said its good but if the sun gets on it they cant see much and during a race thats not much good, be good to see how you guys gte on with them.
Old 30th October 2007, 16:34
BIG_Fella's Avatar
The set up for a k series would be best part the same
As for the sun getting in the way of seeing the dash the same can be said for any dash
I have set mine in a bit to try and minimis the glare
Old 1st November 2007, 08:36
Yeah I was gonna try and set mine back in the binicle to reduce glare too.
Unfortunately it seems I may have to wait alittle longer for the chassis, according to Terry yesterday the move has not gone as smoothly as planned so its likely to be late Nov/Early Dec at the earliest now.
Old 1st November 2007, 15:04
Oh dear another update, looks like Christmas/NewYear now. At least this will be the most planned project when I get to start it.
Old 2nd November 2007, 00:32
grant620 grant620 is offline
grant620 is on a distinguished road
You considered the Acewell Dash?
I use this one:
http://www.quadtech.co.uk/?section_i...product_id=276
Old 2nd November 2007, 13:42
BIG_Fella's Avatar
That is a nice dash unit
The only prob would be the SVA test there may be a prob getting it to pass
Old 2nd November 2007, 19:03
It is SVA compliant as long as it's used with the optional lighting unit (then it's called the 3950).
This unit is fitted as standard to a few kit cars that are factory built (Spire is one)
Old 2nd November 2007, 19:43
Nope that wasn't one I'd come across before its quite similar in style in someways to http://www.race-technology.com/dash2_2_31.html that is SVA compliant so am sure the Acewell one is too with illumination as you say.
The main reason I'm considering the ETB one is it seems the best compromise between functionality (inc datalogging) and price. But there's plenty of more umming and erring yet before I make a decision
