Old 5th March 2010, 09:30
nutter's Avatar
nutter nutter is offline
nutter is on a distinguished road
Default Instruments
Just wanted to know what people have done with regards for instruments
Used Donor? Honda/Rover/Audi?
Used Digitial all-in-one dash?
Used custom dash? What instruments? ETB? What size 100mm or 80mm? etc etc
My current thinking is I am going for 80mm ETB with white dial, red needles, brushed aluminium bezel, and a range of 52mm dials to complement them.
Thoughts, advice and tips please
Steve
Old 5th March 2010, 10:25
Chris Cussen's Avatar
Used ETB gauges on my cabrio. They seem to be good quality, no more expensive than off-the-shelf gauges and worked first time.
The speedo was a doddle to set up after I got my sums right
I went for chrome bezel, black dials with white needles and legends.
I did cock up the mounting of the speedo sensor though. I put the magnets on the prop shaft just at the gearbox tail and the sensor on the gearbox mounting bracket. I had a problem with the gearbox moving and tried to move the read-off point to the diff, and in doing so broke the sensor and magnets. ETB sent me new ones within a couple of days of a phone call.
Old 5th March 2010, 12:57
limpabit's Avatar
limpabit limpabit is offline
Just used standard Rover gauge that came with a mk3 Rover. Electric speedo. Sensor wire was included in the Marlin loom so just used it. Only needed a switch positive and earth on the sensor end and worked ok.
Original speedo (early Rovers) used cable speedo drives. Not electronic.
Have been thinking about other istruments. I did like these, but is a bit pricey!
http://shop.aim-tec.co.uk/mxl-strada...aphics-4-p.asp
Old 5th March 2010, 16:25
alackofspeed's Avatar
I used a Civic Type-R instument cluster, and have since added an oil temp gauge - glad I did, as initially track oil temperatures were problematic.
Old 6th March 2010, 22:18
DavidH DavidH is offline
I am using an all in one digital dash - Dash 2, paired up with a DL1 datalogger. Both from Race-Technology, they have integrated well with Rover Sensors and have plenty of capacity left for some more tricks post IVA when I really start building the car.
Old 8th March 2010, 19:39
JAC.Sports's Avatar
JAC.Sports JAC.Sports is offline
JAC.Sports is on a distinguished road
I'm using Revotec individual gauges, which are smiths just with a different faces;
80mm Tacho & Speedo,
52mm Oil Press, Oil Temp & Water Temp
I have a PI Research Omega 2 Dash Kit with a Clubman logger on order but not due till the autmn & they are good but not sure about IVA compatabilty.
Jon
