Hi Mike,
as Chris has said, they may be OK, but my approach to my SVA was to remove all possible doubt and discussion.
For example, I fitted some cheap 'e' marked side indicators (Fiat) for the test and then I swapped them out for the ones I wanted after the test.
If the're 'e' marked he won't 'bat an eyelid' but if they are not he has got to satisfy himself they are equivalent, but how can he do that?
The less things for the inspector to worry about the better.
With the cost of re-tests its worth 'removing all possible doubt' !
On Ian's point, I think there is an issue with the new 'angles of visibility' in the revised IVA. Presumably, on the Sportster, the front mudguards and/or wheel obstruct the visibility of the side indicators mounted in the convectional position. (Imagine the discussion between Mark and the IVA inspector
But I think on the Cabrio, your side indicators are mounted on the edge of the front wings so I think you'll be OK.
...peter
