Old 4th September 2013, 16:55
Default Spray filler (hi build primer)
I want to do the high build primer bit myself, a handful of weeks away.
I won't be using 2k, a browse around the mig welding forum will show some really sad stories about the damage this has caused to amateurs.
So I will be using celly. Problem is that this stuff shrinks (or sinks). How long to I have to leave it to let the solvents evaporate? I have found at least a couple of weeks, is that enough?
Old 4th September 2013, 19:11
seanick's Avatar
seanick seanick is offline
What's the problem with 2 pack?????
Easy peasy!
Mix it accurately...use digital scales or graduated mixing pots.
Add thinner until it's runny enough to spray.
Put it in you gun
Practice on a big bit of card getting the air/paint ratio nice.
Spray it!
In this weather you can overcoat in an hour
And sand it the next day.
Why use cellulose?
The net is full of misinformation!!!!!!!!!!
Old 4th September 2013, 21:52
What about rhe middle ground of a iso free 2k?
