Old 2nd July 2014, 18:39
completenovice22 completenovice22 is offline
completenovice22 is on a distinguished road
Default Boot Fitting
Hello peeps, how things hope your all enjoying the long days so you can spend more time in the garage
A question for you all. Boot fitting on the mx, when I put the panel in the locking mechanism locks but refuses to open when the panel sits flush. When I put a seal around the edge it raises the panel but the boot release now works! And it lifts the boot panel so that it doesn't fit flush which makes the car look horrid. I've tried dropping the mechanism and raising it but still can't get it to release when the panel is sitting flush with the rest of the body. Any clues
Old 3rd July 2014, 07:07
Are you building hard or soft top?
Old 3rd July 2014, 11:57
Peepsy Peepsy is offline
Peepsy is on a distinguished road
If your boot release works with the panel raised but not when it is flush.It sounds like the boot lid is binding on the body. A few picture of hinges and release would help ?
Old 3rd July 2014, 12:26
Hard top drummajor
I'll try and get pics on peepsy
The boot lid sits flat without the seal in place and locks but won't release. With the seal in place the boot also locks but will release. Its fitted with mini boot hinges. Its as if it needs pressure against the lid to make the mechanism release
Old 3rd July 2014, 12:55
You have answered you own question. The mazda hinges have springs to pop the boot. You need something like a spring to lift the boot enough for the lock to disengage.With regard to the seal. The boot lid is almost as deep as the recess for it. some have remade the lip on the body like seanick. Others have fitted a very flat u shape rubber. Good luck.
Old 3rd July 2014, 13:27
I had to make the boot on my BMW pop. I got this thing
Basically a bolt with a spring behind it that pushed the boot lid up.
You will need to adjust yours so it is correctly aligned when being pushed up.
Old 4th July 2014, 19:27
Thanks Peepsy/WCA I'll try a version of your remedy WCA.
Old 4th July 2014, 19:49
Or even gas struts, cheap on ebay, even cheaper from a srapyard.
