Old 7th February 2015, 15:28
Dave1954 Dave1954 is offline
Dave1954 is on a distinguished road
Default pinto flywheel
i bought a part finished robin hood,it has auto box that i want to change to manual.i know nothing about auto,s would i need to change flywheel also. ford pinto 2 litre Cheers Dave
Old 7th February 2015, 22:13
redratbike's Avatar
Pretty sure you need manual flywheel, clutch .gearbox,pedal box,or just the clutch pedal and cable.
Old 7th February 2015, 22:33
As redratbike says, with auto's there is no 'flywheel' only the torque converter and a thin disk to carry the starter gear.
Don't 'know' the Ford setup but be careful of the spigot bush, often on auto engines the spigot bush is steel (cheaper?), with manual gearboxes it needs to be bronze or a running bearing. I discovered the difference the hard way after fitting a manual box to a Rover P6 auto engine.
Old 7th April 2015, 06:24
Check out a Haynes manual, you should have pictures of both? I don't have the Cortina Manual.
Old 7th April 2015, 10:09
ozi jim ozi jim is offline
ozi jim is on a distinguished road
Tailshaft will most likely be different as will the crossmember.
