Old 31st May 2006, 12:28
MartinClan's Avatar
Default Clutch fluid reservoir and pipes
I would like to know if anyone has used the standard BMW fluid reservoir for the clutch, and if the standard bmw pipes will fit. Just weighing up the various options for brake and clutch fluid reservoirs....
Old 31st May 2006, 13:15
Patrick's Avatar
Patrick Patrick is offline
I'm not using the standard one, but have used a piece of fuel pipe to connect it up to the marlin supplied one.
Old 1st June 2006, 22:16
peterux's Avatar
peterux peterux is offline
Lightbulb
Robin,
just came across this........
http://www.fuelsystem.co.uk/hose.htm
Do you know how much the original BMW hose costs new?
regards
Old 2nd June 2006, 07:44
MartinClan's Avatar
Default Original BMW hose
It's about £4 as is also the reservoir. I think you have to be a bit careful about what hose you use for hydrollic (can't spoll) fluid. I read of someone failing the SVA becuase they had used a remote reservoir and not used hose that was specifically marked for the use.
Old 2nd June 2006, 07:51
Patrick's Avatar
Hmm I should get something else then. This SVA stuff is a bit of a headache!
