Old 4th June 2006, 17:43
MartinClan's Avatar
Default Goo for floor fixing
I am about to rivet in my floor. What goo have people used as a sealer? I seem to remember someone using sikaflex - but which one - there are loads of different types.
Old 4th June 2006, 18:17
Patrick's Avatar
Patrick Patrick is offline
I've been using this stuff to seal the chassis, very strong and rubbery when set. I do plan to use it for the floor too: http://www.frost.co.uk/item_Detail.a...lack%20(310ml)
Old 4th June 2006, 20:12
JG's Avatar
JG JG is offline
Big Cheese
JG has disabled reputation
A polyurethane sealer will do the trick (sikaflex make is the one most commonly known) CBS have it on page 26 of their latest online catalogue.
Cheers, John
Old 6th June 2006, 12:22
MartinClan's Avatar
Thumbs up Goo for sealing floor
To answer my own question for anyone else that needs the info
Its Sikaflex 221 or 290. Bought mine on ebay (old stock) for £5 a tube
Old 11th June 2006, 22:07
peterux's Avatar
peterux peterux is offline
Cool
Robin,
so how did the floor fixing go?
Have you got any good tips?
Do you have gaps/holes at the end of the tunnel behind the seats? Is this to let the water out when it rains?
Old 12th June 2006, 12:33
MartinClan's Avatar
It hasn't yet! Away at the weekend and just too hot at the moment. The Sikaflex cure time is pretty short and also temperature dependent!!
Yes I have got the holes. If I was to be charitable I would say it is to let the water out (but of course it will also let it in) Or it could be Marlin just didn't put a flange in that place...
Could be worth leaving though for that reason. I once got caught in a thunderstorm in my first kitcar, which had a fibreglass floorpan (hmm) - within about 2 minutes there was 3" of water sloshing arround in the bottom - I am used to bailing out boats, but never had to bail out a car before.
Old 12th June 2006, 20:17
peterux's Avatar
Robin,
the holes look too deliberate?
Perhaps there is another reason, like the missing door strike plates that I assumed was an error, but turned out to be (not) there for a reason.
Anybody else got any suggestions?
Old 19th June 2006, 20:28
MartinClan's Avatar
Red face Advice for fitting floor
A couple of points for fitting the floor (more to come)
1. Don't use too much sikaflex - it makes helluvamess....
2. Dont sit up under the car when applying it when the wife comes out to the garage to ask you something that won't wait.... Its a b*gger to get out of your hair
3. On a more serious front - according to one of my boaty friends meths is a good solvent for it - but beleive me not good as a shampoo....
Old 19th June 2006, 22:39
Patrick's Avatar
At least your having fun, might need to go for a bit of trim to get the rest of the black stuff out
