15th January 2007, 17:31
fuel cap and mirrors
What fuel cap and filler have any builders gone for,are there any sva issues with filler neck size and does sva dictate the mirrors used?
15th January 2007, 18:49
I've using an aero type filler cap, you need an unleaded flap to inside the filler neck to pass SVA (I can see why I don't remember the last time I saw leaded at the pumps!) - the other issue with SVA is minimum radius of the edges - some aston type caps will not pass so if you want to use for one of those you need to look for one that is specifically designed to pass SVA.
Also have a set of chrome bullet mirrors but these wont pass SVA. Spotted some cheap universal fit plastic folding mirrors in halfords. The mounting system is such the the bullet mirrors can be fitted, taken off and the halfords one put on in place for SVA.
SVA spec for mirrors is a minimum size and the ability to fold if someone were to be hit by them. Don't remember the exact specs of the top of my head.
15th January 2007, 19:05
Hi,
I've fitted a Mocal cap from Demon Tweeks.
Follow this link and have a look.
http://www.demon-tweeks.co.uk/produc...code=MOCCAP3ZF
If you have a look at the PDF file on this page, the one I have is image 3.
It's beautifully made, lockable and is adjustable as well to ensure sealing.
Rob.
15th January 2007, 19:49
fuel filler
Rob, is ur one sva safe?cheers
15th January 2007, 19:58
Hmm - I thought you only needed the flap if you were running a cat? - perhaps someone would like to correct me on that?
15th January 2007, 20:02
Everything I've read so far has said you need one, but if anyone can correct me
15th January 2007, 20:20
Just found this in the SVA manual.
b. On vehicles that require a “Catalyst Test” (see
Section 18, page 2), check that the fuel tank
cannot be filled directly from a petrol pump
nozzle having an external diameter of 23.6mm
or more.
So - my interpretation is if you don't have a cat you dont need the flap/restrictor in the fuel filler.
Would anyone else like to comment?
PS for Patrick The 318ti was pants - something wrong with the clutch (also felt nowhere near as quick as my 318is :-) )
15th January 2007, 20:24
Hmm well I have one that people can borrow for the test if needed when I'm done with it, same goes for the mirrors!
PS, wrong colour anyway! Richard's compact is nice and quick now Not sure the E36 will ever feel as quick as your E30 due to the extra lard!
16th January 2007, 16:58
The neck of the Mocal cap is machined in such a way so that a restrictor can be fitted and secured with a circlip.
I should have taken photos.
28th January 2007, 10:55
I have a standard filler with no adaptor and as my car dosnt have a CAT it wasnt a requirement for SVA and passed.
