27th June 2013, 08:07
That was really good, that car really did look like it came from the 50's. I like seeing all the switchgear, and the aluminium panels... And the exhaust!!! Lots of ideas.
27th June 2013, 18:49
The side exit exhaust is the same as the original Lancia D24, and doesn't the 2CV motor sound great with no baffles! Awesome.
16th July 2013, 05:55
16th July 2013, 05:56
16th July 2013, 05:57
16th July 2013, 09:12
Lots going on! Hoping to get started on fitting my frame next weekend, one point is this a Sammio or a Ribble? BTW love the hole punch :-)
16th July 2013, 10:01
Thanks viatron !
It's a SAMMIO CHEVAUX indeed, maybe number 2 or 3.
RIBBLE is the new name of the company since january 2013.
16th July 2013, 17:53
Great work , looks very smart ![Hail](images/smilies/hail.gif)
16th July 2013, 20:04
Looking good - will it look a little like this one (at Stoneleigh this year) ?
I thought the exhaust exiting in front of the rear wheel was well executed.
![](http://i1272.photobucket.com/albums/y390/CaptLockheed/Stoneleigh2013038EBW_zps1a67b1b0.jpg~original)
18th July 2013, 05:46
18th July 2013, 07:29
One sheet of plywood, 2440x1220x9mm (shuttering ply is fine), is enough to line the inside of the cockpit. I used glass fibre to finish off the curved rear corners, but the designer cut triangular wooden fillets and bonded them in.
http://www.sammio.co.uk/Gettingstarted.aspx
Looking very nice now by the way, you'll have a car to be proud of in no time. ![Smile](images/smilies/smile.gif)
18th July 2013, 11:31
Thanks Mr T for your response.
In fact I need also wood to buit my luggage's compartment so I've bought one sheet of plywood but in 3100*1530*12mm.
18th July 2013, 13:08
![flyingbrick's Avatar](image.php?u=5088&dateline=1352046903) |
Would aluminium sheet not be lighter to use, would help to keep the weight low and would stiffen your frame if rivuted on. Great work so far by the way ![Smile](images/smilies/smile.gif)
18th July 2013, 15:53
![cabbage's Avatar](image.php?u=5438&dateline=1368439594) |
Aluminium has a lot of advantages when lining the cabin but is very expensive and i would imagin takes a lot longer to do, so i can understand why most opt for using wood.
My tub is aluminium and bonded/riveted which definitely gives the car a solid feel.
29th July 2013, 05:51
Others pictures !
It's not very easy to cut all the parts in wood at the good size but with a litle time its 'done :
Back sides :
And with the two side panels :
Back view :
a clean garage isn't it ?
This week, I will paint the frame.
1st August 2013, 05:59
1st August 2013, 06:39
Looking good Zeb !
Have you thought about fitting the more powerful 1.2 boxer out of a gs clubman
citreon. Would be a nice power plant for this low weight body.
Also what car do the lights come from, they are a nice scale for the car.
Keep up the good work . ![icon_razz](images/smilies/icon_razz.gif)
1st August 2013, 07:20
Thanks Mikmiglia.
In fact I have hesitated a long time between the 2cv motor and the GS Motor (GS motor is the same than the AMI SUPER motor) but I wanted to built the car the much closer to registration papers of the car. So I 've keep the original 2cv motor.
I don't want to race with the car, only for pleasure and I like to take the time.
My lights come from CITROEN Ami6 or CITROEN DS estate.
5th August 2013, 06:12
Sebastien - Your build is coming together very nicely.
Bon chance, Paul. ![Smile](images/smilies/smile.gif)
28th August 2013, 09:43
good news :
All the wood panels are done and the body is fixed at the frame. I've to work on the bonnet now, not very easy to do !
I've done a lot of pictures during my holidays, I'will put them as soon as possible !
